- 4 Jan 2004
- Finally, Swindon
First venture into this subforum, and I hope someone can help
I recently moved to an old 3 storey townhouse and have virgin fibre to the lounge/sitting room at the front ground floor where the router and tv box are. The guy that used to live here had wired up internet co-axial (I thought co-axial cable was what was used to connect terrestrial tv to an aerial, but this is obviously different/higher grade stuff) to 4 other rooms. He had 3 routers attached and explained this was the only way he had found to get wifi throughout
So in my ignorance, I bought 2 other Hub 3s and wired them up, as he had done, after putting a splitter in and connecting up the previous owners cabling. This is the point I find that you are only supposed to have a single router attached, and is probably why the 2 I've purchased won't work. A bit of swapping around shows the 2 I have bought are functional, just not with another router attached. The guy actually worked for virgin so I assume he knew what he was doing, so whether he'd done some fancy jiggery-pokery I don't know
I've tried out some plug in jobs that I had lying around that use your electrical system, but my guess is that the electrics are pretty old because I can't get them to work, except in the room next door...not v useful!
Is it possible to mess about with the now 'spare' router settings and get them to function - I suspect not as after seraching the virgin forms it seems I'd need 3 separate subscriptions to run 3 routers
Assuming that's not possible, is it possible to attach the router downstairs to make the existing co-axial network 'live' - I'd assume I'd need some special adapter to go from the router to the co-ax? Do they even exist. I'd need something similar at the other network terminations to reverse the adapter
It just seems a complete shame to not be able to use the wired network
Any advice, before I do something stupid and buy more useless kit?
Thanks
Thanks
