Ethernet (Intel onboard NIC) shows 1gbps connectivity.
It's directly connected into the BTHomeHub, I've also tested having only my PC and HomeHub on the network.
Just swapped over the network cable from the back of my PC to the HomeHub too.
Just copied over a 550MB file from my NAS to my PC, without any ping degradation. So my NIC is totally capable of handling high throughput, and so is the HomeHub switching capabilities.
Hop #2 --> 2 30 ms 20 ms 15 ms 172.16.16.61
This is where the latency starts in my opinion? This is the default gateway (aka - another router on BT's network) down the other side of the copper wire leaving my house. The latency starts at that hop, not my router - so doesn't that rule out a local issue?
The only SNR value I can get is this in the troubleshooting log from yesterdays reboot:
19:08:29, 07 Feb. DSL Link Up: Down Rate=72420Kbps, Up Rate=20000Kbps; SNR Margin Down=3.4dB, Up=6.7dB
Edit 2: This smells of a local issue rather than the Internet connection. Your latency increases before it even leave your router judging by the tracerts posted earlier
