- 12 Feb 2006
- Surrey
i'm doing some work on our driveway to widen it so we can fit our cars better on it without blocking each other in. we have one one side a raised section, about 40cm off the drive way, which we'd like to remove as it's wasted space and is big enough of a space for a car so you can imagine getting it to the level of t he drive will be beneficial to us.
my concern however is that the 3 neighbours fence that goes to this drive, they have been concreted in only about as low as our drive way as the fence uses my raised bit for support. you'd be left with a 40cm gap below everyones fence, and the concrete now poorly supported.
i'm in 2 minds about what to do. I could try leave a small bit of the raised section, however really i'd like all this gone as i'll have to do more work to make it neat where it's been left.
so i'm then thinking screw it, it's their problem the fence has been poorly installed, relying on my section to support their fence.
i might go round and tell them my plans and see what they say, but wanted to see what others think. I assume i wont get in trouble for removing my part even if it reduces the strength of their fence?
just one thing to note. although i say neighbours. this is actually the back of their garden and they are on a completely different road/estate, so i'm not too worried about keeping them sweet as i will never see them again.
i've made a handy picture so you can get a good idea of what i'm talking about. it's the dark grey section i want to remove, and the north side fences will be affected.
