On my other PC the one I do all my writing on was playing up big time this week. It was really strange how it all started, with intermittent blue screens and when I turned the computer on at the wall, the system would power itself up without me even touching the power button... When this happened it would come up as overclocking failed as If I was hammering on the reset button or powered it down mid boot.
Suddenly on Friday I tried to power up the system and nothing was working and after about an hour it started working again, atleast until yesterday! I was up till 3am in the morning using it, but by the morning time nothing would work, no power whatsoever. I tried every combination and power supply testing and still in the times it did power up, the fans were running at half speed and all my LED lights were flicking which meant something was way off on the board.
Upon reading a reddit post I saw someone mention they had the same issue and even after clearing the CMOS and leaving the battery out it wasn't until a new CMOS battery was put in it started working.
Sure enough I got a new CMOS battery, put it up and it powered up first time, everything works as it should and is perfectly stable in all benchmarks/testing.
This is rare to happen as when a battery fails most of the time the bios doesn't save or clock is out of wack, but according to these users with the same issue, the CMOS battery can put the system into a permanent off state, meaning it's always going to stay OFF.
So there you go if you have this issue, try a new CMOS battery first!
Welcome.
