vulkan t force vs vulkan tuf gaming alliance
just to help other OCUK'ers the ram on my tuf alliance is not samsung B die
its hynix
Its working fine, but I checked it and its hynix.
So I guess the £20 premium was just for the heatsink design and tuf brand (asus tax).
Code:
Manufacturer
Hynix
Part Number
H5AN8G8NAFR-UHC
Package
Standard Monolithic 78-ball FBGA
Die Density / Count
8 Gb A-die (21 nm) / 1 die
Composition
1024Mb x8 (64Mb x8 x 16 banks)
a simply google shows people complaining that they have not got samsung Bdie's on the TUF stuff
HOWEVER, if gibbo as said there all unbinned SAMSUNG Bdie's then you can return them because... there not
just to be clear lots of people are saying all over the forums that "gibbo said"... but i have not seen the post where gibbo did say it.
@Gibbo is the tuf stuff supposed to be Samsung dies?
They are all same IC, point is you could have saved £20 or got faster SPD stuff. 3200C16, will do 3000C15 all day long on an Intel platform, probably even C14.
To be honest this is best 3000 kit value for money wise:
Team Group Vulcan TUF Gaming Alliance 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Blac @ £119.99 inc VAT
TLTYD416G3000HC16CDC01, 3000MHz RAM Speed, CAS 16-18-18-36 Timings, 1.25-1.35v VDIMM, Lifetime Warranty with OcUK.
Only £119.99 inc VAT.
ORDER NOW
As it is B-die (unscreened), Corsair 99% won't be, B-due tunes and OC's better seen them as low as 3000C12 or as high as 4000MHz even on none screened stuff.
its hynix
i'd be bummed to pay an extra £20 for virtually the same ram as the t force. especially when it was said to be b-die
send it back and get the £90 ram?
bait and switch sucks. i expected better.
@MaXxBoulton
if we're going to go all pedantic. granted micron and samsung does b-die, for the purposes of an enthusiast forum, saying b-die is as good as saying samsung b-die.
yes assumption is the mother of all **** ups, but it's a bit disingenuous to say b-die and then say later "oh i meant micron b-die"
in any case, it's hynix, who don't even do b-die! lol ;)
@MaXxBoulton
i agree, but this is the world of sales.
like i said ever way gibbo did say Bdie and the buyer got Adie... so he as been done wrong buy and i would lose my poo on the phone.
its hynix A die so not even B die of any brand ;)
I will put it through hci memtest, and if it fails the phone call might go in yeah, but if it passes I may let it go as I didnt plan to overclock it past XMP spec.
I didnt do hci memtest runs as too slow, but I did some on karhu ram test which is probably 2nd best tester behind HCI and is fine.
Not only that I played with settings generated by ryzen dram calculator.
It is also good at 3000CL14 same 1.35v
and 3200CL14 but with higher dram voltage 1.38v
Hynix A die seems to be 2nd best behind samsung B die from what I read.
So I wont be ringing OCUK although I do think gibbo deffo needs to edit his post as its misleading people.
I got the T-Force and mine is micron. The various memory tools don't seem to know what to make of it! Works at 3000 as advertised bit not even 3066 works. Cheap though.
