I have a friend who has finally managed to get hold of his Radeon V11, from a small company he has local to him in the Netherlands. Now we love to banter back and forth about the whole NVidia vs AMD thing and to be honest I was really looking forward to his views on the Radeon V11 that he has had now for a just over a week.
Now as many of you he was excited to start to use the new card and straight away he said it was unbelievably loud, and ran far too hot for his liking. I pointed him to various reviews that have talked about undervolting and adjusting the fan profile in the wattman driver utility, to bring the power usage and fan noise under control. at first he had quite a good bit of success and he managed to he put it, bring the power usage and therefore the noise under control somewhat.
Now all seemed to be going swimingly and he was happy as Larry with his new card. but then disaster struck and his card went pop for no apparent reason. Now I have told him that it was nothing he had done and sometimes these things happen. He should contact the company he bought it from and they would sort out a replacement under warranty.
Well he did exactly that and he told the shop what had happened, but he made one fatal mistake, he told them that he had used wattman to change the fan profile and undervolt the card. Now as far as I am concerned this shouldn't be a problem, but the company that he bought it from is refusing him warranty due to him running the card outside of AMD's specifications.
Basically because he used the wattman utility that is built into the driver suite to change the fan profile and undervolt the card, he is diddled out of a warranty claim, just because he told the company about doing it.
Now it does say on the AMD adrenalin edition webpage.
So basically if you mess with anything that changes the factory settings, even if you use the built in wattman utility, you void your warranty.
Does wattman warn you before you use it?
Now I have told my friend that he should contact Powercolor direct and don't mention that he has undervolted or changed the fan profile and hopefully they will be able to sort him out, as a dead card is a dead card and that shouldn't happen with a new card at all.
OVERCLOCKING WARNING: AMD processors are intended to be operated only within their associated specifications and factory settings. Operating your AMD processor outside of official AMD specifications or outside of factory settings, including but not limited to the conducting of overclocking (including use of this overclocking software, even if such software has been directly or indirectly provided by AMD or otherwise affiliated in any way with AMD), may damage your processor and/or lead to other problems, including but not limited to, damage to your system components (including your motherboard and components thereon (e.g. memory)), system instabilities (e.g. data loss and corrupted images), reduction in system performance, shortened processor, system component and/or system life and in extreme cases, total system failure. AMD does not provide support or service for issues or damages related to use of an AMD processor outside of official AMD specifications or outside of factory settings. You may also not receive support or service from your board or system manufacturer. Please make sure you have saved all important data before using this overclocking software. DAMAGES CAUSED BY USE OF YOUR AMD PROCESSOR OUTSIDE OF OFFICIAL AMD SPECIFICATIONS OR OUTSIDE OF FACTORY SETTINGS ARE NOT COVERED UNDER ANY AMD PRODUCT WARRANTY AND MAY NOT BE COVERED BY YOUR BOARD OR SYSTEM MANUFACTURER’S WARRANTY.
