Hi All,
Backstory (Don't need to read this bit)
I built myself my first gaming PC around 5 years ago after seeking build advice from this forum. The PC has served me incredibly well especially considering the fact it was only £1000 and played everything I threw at it with no problems including VR!
Sadly, my computer died and during the process of tearing it all down for a 4th time the plastic PCIe connector peeled off the motherboard and bent a handful of pins. I'm fairly sure the GPU has packed in so it's time to upgrade now I need to replace both the GPU/Mobo...
I've tried using the configurator but A) It seems really overpriced and B) thee myriad of options is just too confusing considering that so much of it appears to be identical on the surface but at completely different price points coupled with the fact that the information I'm finding on the internet tends to be extremely contradictory everywhere I look...
So that's where I need your help again OCUK members if you can spare the time! I'm looking for a good bang-for-buck upgrade that's going to last me another 5 years or more.
Current PC
Sapphire Radeon R9 290 Tri-X 4096MB GDDR5 PCI-Express Graphics Card
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM
Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard
Samsung 120GB SSD 840 EVO SATA 6Gbs Basic
EVGA SuperNova NEX 750W 80 Plus Bronze Power Supply
BitFenix Ronin Tower Case - Black
TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit
Seagate Barracuda 2TB 7200RPM SATA 6Gbs 64MB Cache - OEM (ST2000DM001) HDD
Raijintek Themis Direct Contact CPU Cooler
EVGA SuperNova G2 850W '80 Plus Gold' Modular Power Supply
Probably not going to salvage anything from this other than the SSD/HDD most likely... I don't think I kept the PSU modular connectors and it's probably worth just buying a new one anyway I guess?
New Build Considerations - £2,000 Budget (Can go slightly over if necessary)
Main Purpose - Fairly heavy gaming at 4k if within budget and reasonable but quite happy to stick to 1080. Emby/Plex. Some Hyper-V lab stuff. Some VR gaming. No streaming/photo editing/video editing although would prefer to be able to do this in those rare instances. Doesn't need to be flashy/RGB and all that nonsense.
Case - Not massively bothered here. I've been looking at the Be Quiet! 900 which is rated very highly it seems but it rather expensive or the Lian-Li PC-011 which also showed up quite a lot.
CPU/Mobo - Looked like a total minefield with very contradictory information. The i9-9770 looked like good bang-for-buck but I'll need you guy's expertise on this.
GPU - Going to need something meaty here of course. Was looking at the 2080Ti which will likely blow half the budget but I'm sure will easily last 5 years if reliable. Was a total minefield again with so many brands at so many prices... will take your advice here!
Cooling - Again, I'll take your advise but looking through the configurator I quite liked the Be Quiet! Silent water cooling thing...
RAM - Ideally want 32GB
Storage - I've got an SSD and HDD as well as a x4 6TB NAS so storage isn't much of an issue however I quite liked the idea of the 2TB NVMe that I saw in the configurator. Extremely fast speeds and plenty of storage so I don't have to split everything.
Lastly... A huge thankyou in advance and I look forward to seeing any responses!
Current PC
