I texted an 07 mobile number today and got charged £1.75
12 Feb 2006
Surrey
I texted a standard UK 078xx mobile number and I got charged for it by ee.
Anyone want to guess why? I have the answer but it totally shocked me and is something I find ****ING ridiculous that this is a thing.
Some 078 numbers are not standard mobile numbers but are more expensive. It's also possible this number was in the Channel Islands which, I believe, doesn't count as part of the UK for telephone calls and mobiles. Your mobile provider will likely be able to explain more if you ask them.
Yes it was a mobile number from Guernsey. Ee told me not to worry as when I call they give me about 2.5 nanoseconds of warning to that it will charge and to hang up. I explained I text and she said that yeah they don't warn you then. So you can get charged to text a UK mobile number!
Even more stupid I found out that if I call or text a UK number that has gone to say France and I don't know, I get charged for that too.
I think this is the dumbest thing I've ever heard. Its possible to text or call a UK mobile number and get charged for it.
Not sure this is correct - my wife is with EE and if she calls or texts a UK mobile number, while she is in the UK, it is included within her allowance! (After all, as you say, you don't have any knowledge or control over where that number is!)
Pretty sure that's not the case (it certainly isn't the norm). The sender of the text or phone call gets treated as if they're texting a normal UK number, regardless of where the recipient is. The recipient may get charged to receive that call or text depending on where in the world they are and what plan they're on with their carrier, has nothing to do with you though.
Guernsey isn’t the UK so texting a Guernsey mobile number will result in an international text charge.
This is correct. Regardless of where in the world a UK number is the person calling or texting it from the UK won’t pay for the privilege. It’s the recipient of the call or text that’ll pay (if there is a charge to receive).
This is what I believed but she insisted that what is aid above is correct that we get charged.
Yes I agree but then they should not have 07 numbers. UK mobile numbers start with 07 and I don't feel it should be possible that a number can look exactly like a UK mobile number, and not be one
Well I don’t know whether we can dictate what numbers Guernsey uses! They are their own sovereign state. All they share with the UK is an international country code.
A million years ago I went through training with CPW and I remember being told the principal was if the sender or caller was ignorant of the location of the recipient the recipient paid.
So if you don't use a country code the recipient is on the hook.
So basically you'd sent a text to a premium number which should have been obvious and you've known it, you've used a country code and known it or it's a mistake you can easily challenge..
Done.
Done.
The only oddity in this situation is that although Guernsey is a different country it shares the UK international code so there is no international dialling code attached to the number.
Jersey and the Isle of Man fall into the same category.
Well then following the principal, it's not your problem.
This sort of thing is regulated so it's either a UK number or it isn't, if it isn't then you'd have to know before you called or text it to make the charge applicable.
Seriously networks are so heavily controlled to ensure they can't hide charges you'd need to be supplied with a list of all non applicable numbers to make it chargeable. It just wouldn't be workable.
Otherwise, it's on EE basically.
I think they do tell you in the T&Cs which number ranges are not UK numbers.
Trust me.. 078xxx is not in that range... 100%
I know a couple of people with 0787xxx etc, no way you could know that was Guernsey
