It was released only in 2008.
(I have older PC-A71B)
With almost completely metal construction there's very little which could rot in them.
While it could definitely use some modding in few places it would be well usable.
And right now you won't be getting any single CPU which would be future proof, no matter how ludicrously overpriced.
Intel is ahead in single thread performance, but only because of second rate GlobalFoundries' node... Bought from Samsung and developed for low clocks phone/tablet CPUs.
Zen2s made on TSMC's 7nm high performance node more advanced than Intel's manufacturing tech won't suffer from that.
And they'll bring extra cores needed for future proofing against next-gen console multiplatter games.
Wintoys PC has whole lots of bloatware/overhead to run in addition to game, while lacking advantage of coding for fixed hardware.
And those next-gen consoles likely come with 8c/16t Zen2 based CPU.
Waterpipe coolers need to dissipate heat to air just like heatpipe coolers.
They even add pump as extra noise source and with higher number of fans they aren't usually good in cooling per noise performance.
Whole lots of "reviews" (more like paid adds) fail to measure noise corresponding to cooling result.
Or use some stock garbage or cheapo as comparison instead of good high performance heatpipe cooler.
Also with lot more things to break/degrade (mostly catastrophically for cooling) you certainly can't forget them into PC for whole decade like you can do with heapipe cooler.
And that's why you always aim CPU cooler and its fan to push that heat toward case exhaust fan.
In case of these Lian Lis there's also room for heat to move upwards instead of being stuck at level of components.
Great read and lots of information to take in, thank you - need to look into the life cycles of the prebuilt water cooling!
These days, I would get a Freesync screen that is G-Sync-compatible.
Without sounding stupid what is freesync? /gsync?
