- 14 Mar 2011
Hey all, looking for ideas...
Last year I built a water feature in the garden... (skip this paragraph if you don't care and want to just get to the question). I bought a metal "tree ring" which I sunk into the ground, then filled with stones/pebbles to create a level base, onto which I put a half whiskey barrel. I lined the barrel with a pond liner using tacks around the rim at the top, then stood ~5-6 bricks on-end in the bottom that are supporting a steel mesh, and onto the top of that are some larger pebbles arranged to create a pool. So rather than being a "pond" the depth of the barrel, it's more like a shallow pool (for birds etc). There's a submersible pump in the centre that bubbles up through a stack of rocks in the middle... It works, looks and sounds good, but it's leaking - the barrel isn't watertight in the first place (hence the liner) but my guess is that they liner has a few small tears in it somewhere that are slowly letting water out. Combined with a bit of evaporation and the occasional drops that splash out of the feature from the fountain I'm finding it needs refilling much more regularly than I hoped! (doubly not ideal as tap water leads to more scummy algae etc)
So TL;DR the barrel/pond liner combo I have is leaking (slowly), so I want to drain it, dismantle it, let it dry and try again (the rocks and things need scrubbing anyway)... my question is what can I do to the barrel that will make it watertight rather than relying on a pond liner again which can get ripped or fail?
Things I'm considering:
* Maybe I could get a tube of Dowsil 781 or similar silicone sealer, cut the tip open as finely as possible and then run it up all of the gaps between the barrel slats to try and plug any leaks?
* Some sort of waterproofing paint (like Flex Seal except you can't get it in the UK) - there are various products out there but I'm not sure what would be suitable...
Failing a good solution I could also just replace the barrel with a "sealed barrel" - I found a site that sell barrels with custom made plastic inserts inside to make them watertight, but they're a bit pricey... or with a stone bowl or some other container that is watertight - but I do quite like the barrel and it would be a pain to dispose of so if I can make it work I'd like to!
