Windows 10 various issues
Caporegime
18 Oct 2002
London
I seem to be having a bad run of problems with Windows 10 installs recently. The latest one is with my HTPC (Ryzen 2500G, 16GB RAM, 4 x mechanical HDs & 1 SSD for boot). I run Kodi on there, as well as an Emby server and remote in a lot using Teamviwer.
  • Downloading torrents seemingly crashes the system
  • The task bar randomly kept reverting to auto hide without me telling it to, almost as if Explorer crashed
  • Random freezes/crashes when using Teamviwer
  • BSODs
  • Green lines on the TV it's connected to and weird issues where the TV acts as if there is no source, resulting in me either restarting the machine or remoting in to force it to wake up (turned off any options relating to shutting down HDs after inactivity)
  • Kodi must have updated to v18 and can barely hold itself together constantly crashing
  • Crashes and BSODs are getting worse
I have checked the temps and they seem fine. My only guess is the boot drive or Windows installation but have never seen a series of issues like these together. Any ideas?
I have a nVME 480GB HD that was intended for my main rig but seeing as I am heading towards reinstalling Windows, might stick it into the HTPC.
Green lines on screen are normally a graphics issue. I would update the graphics drivers with clean install option, if it still continues try another graphics card.
That's encouraging. I really can't be bothered to take my HTPC apart as the M.2 port is on the mobo's backside :o:p.
Yeah this install is ******. I tried to uninstall the AMD drivers, manually first and then with DDU. It crashed installing the updated drivers, tried again and they installed but now it crashes multiple times within minutes.
I would try 2 things now assuming that you are able to get to a command prompt either in Windows Repair during a blue screen or Windows Repair from a bootable usb win10 media. Do a chkdsk to check for bad sectors on the drive and also create a bootable memtest usb drive and run it to check on your ram.
It was the perfect excuse to try out my new nVME SSD. Drivers and BIOS updated, I have told Windows to stop updating drivers (thanks) and it's running like a dream now :).
