Cookeh goes shedding...
13 Nov 2006
I can't see why there's such big hate for this car. One of my family used to own an Aygo and it seemed fine to me. It did huge fuel economy while having super cheap maintenance costs. It even sounded decent. I don't think it needs to be a V12UltraSuperDuperCar+™ to be a good car.
Because most people are car enthusiasts in here. What do most petrol-heads like?
Man of Honour
29 Jun 2003
Wiltshire
I would rather pay the £1300 than drive thing any distance. Nice job tidying up the inside, if it was me I’d run a DA over the outside and sell it on.
22 Mar 2012
I love cars too but I don't see what's so bad about these. They aren't nearly as bad as people are claiming. Sure compared to an s class they are awful but if you actually consider the segment they're in and what they cost to run they're pretty good in my opinion.
13 Nov 2006
Perhaps people want a bit more from their car than:
even at 70mph on the motorway, slight incline and you lose 5mph immediately
22 Mar 2012
Then you just change into 4th. It's not like hills last forever so it's a fairly minor annoyance. That's a problem I've experienced in all of the lower powered cars I've owned and something I'd expect from a car in this sector.
13 Nov 2006
Well, very few people in here will have positive comments about underpowered cars and that's not surprising to me, nor is it elitist.
OP
21 Jan 2010
Ceredigion
My reasons for hating it are fairly well covered so far, but I can do it further. I also don't believe I'm suffering from elitism, my dream car happened to a 25 year old I5 Volvo 850 T5, hardly a "V12UltraSuperDuperCar+" or whatever it was you spouted. I don't believe there is anything wrong with expecting a car to be actually driveable at all 'normal' speeds without causing discomfort. In any case its here for at least 4 months, perhaps more, and I will hate every second of it.
I got a bit more time to work on it today before the heavens opened. I was still trying to make it safe to enter without a hazmat suit at this point, but I'd say its now fairly respectable. Further maintenance cleans of the interior will only improve it, and if I'm honest I don't care about it enough to get it properly 'concours'.
First things first I figured the sparks plugs needed changing, my sister had been advised of this at a service some 200000 miles ago but never did anything about it - despite me offering to do it for her. As it turns out, they weren't terrible. Gap was only 33% larger than spec... Would I be right in saying it looks like it might be running a bit lean too? Removal requires unclipping the airbox (some 4 clips or so, then removing two squeeze clips), revealing your three DI coils with a single 10mm bolt. Spark plugs themselves are your fairly standard 16mm thread. Some pics of old vs new and the three old ones.
Spark plugs old vs new by alistair.hurrell, on Flickr
Spark plugs old by alistair.hurrell, on Flickr
The car runs a little better now, less dag-dag-y on start up and a fraction quieter throughout the rev-range. Still very unrefined but better. Can only hope it gives even more mpg to cover its cost.
Next up it was onto that interior. The rear bench was obviously removed previously, so I tackled that last night inside (thankfully I have an understanding and car-sympathetic fiancee!). This was by far the worst seat in the car, so it got a vacuum, a healthy scrub with upholstery cleaner and finally a steamclean. Came out fairly well I think.
Couple of reminders of the before...
Rear bench dirt 4 by alistair.hurrell, on Flickr
Rear bench dirt 3 by alistair.hurrell, on Flickr
Rear bench staining by alistair.hurrell, on Flickr
Then some 50/50s and finals:
Rear bench 50/50 vacuumed by alistair.hurrell, on Flickr
Rear bench steam cleaned by alistair.hurrell, on Flickr
Rear bench steam cleaned 3 by alistair.hurrell, on Flickr
Much better methinks. The rest of the car wasn't so bad and was unfortunately confined to the outsides so I decided against using the steamer (too much effort being wired and not being able to leave the seats by a radiator to aid drying). That meant a slightly different approach. Copious vacuuming, followed by a huge scrub with plenty of upholstery shampoo before vacuuming out the liquid and giving it a final dry down with some microfibres.
Rear bench upper 5050 2 by alistair.hurrell, on Flickr
Rear bench upper 5050 by alistair.hurrell, on Flickr
Apologies for image quality phone camera had a hard time focusing due to the pattern, and I'm a lousy photographer!
Rear bench uppers after by alistair.hurrell, on Flickr
Passenger seat after by alistair.hurrell, on Flickr
Drivers seat after by alistair.hurrell, on Flickr
And here is the dirt from just the headrest on the drivers seat... Scrubbed with a microfibre as I was curious just nasty it was.
Drivers seat base dirt by alistair.hurrell, on Flickr
So now that the seats are acceptable, minus some loose fibres, it was time to move on to the door jambs. I still can't wash the exterior (apparently), so this is as close as I can get. Quick clean with some APC, a soft bristled detailing brush paired with a small nylon brush, and some microfibres later:
osf after by alistair.hurrell, on Flickr
osr edge dirt by alistair.hurrell, on Flickr
Area under this seal was grim, but came up well. Oddly there are some tar spots in there, and I'm fresh out of tar remover. Will get that at a later date.
osr after by alistair.hurrell, on Flickr
nsr after by alistair.hurrell, on Flickr
nsf after by alistair.hurrell, on Flickr
These were then treated with a spray sealant to try and keep them cleanish for a bit longer.
18 Oct 2002
Birmingham
Well done for cleaning it up. Service it, drive it to save some cash and then sell it when you’re done for a few quid. Nothing wrong with this sort of car if you want something simple and cheap to run around town in. Would be an ideal first car. It’s no autobahn cruiser of course. More people need to drive the original fiat panda around tiny villages and farm tracks in Italy to really understand the appeal of this sort of simple motoring. You could leave this car unlocked and no one would give it a second look.
EDIT - I bet by the end of your tenure you’ll be a little fond of it given the fact that you’ve rescued it and given it some love.
Caporegime
24 Oct 2012
Godalming
It's literally the definition of elitism.
Anyway. I've looked a but more in to that C1 racing and I'm probably gonna go for it. Ridiculous fun on pennies.
OP
21 Jan 2010
Ceredigion
I dunno, it was free and sitting in it disgusted me. Not really any love spent yet :p Just trying to make it so I don't gag everytime I see it. We'll see, I may develop a touch of Stockholm Syndrome...
Would love to, might consider it down the line. Would very much like to get into track days and that would be a very cheap way of doing it. Unfortunately the aim here is to save money not drop £3k on making it into a little racecar haha.
Caporegime
24 Oct 2012
Godalming
Oh absolutely, for someone looking to save some coin there are few ways of getting further away from that goal :D
Still, a 24h race with 68bhp sounds amazing. I must do this. Will need a team.
13 Nov 2006
If your idea of elitism is not wanting a car that struggles to do the speed limit in some situations then I have nothing else to say :)
Caporegime
24 Oct 2012
Godalming
That's not the purpose of the car. It's a cheap runabout for youngsters / those not that well off, and for that purpose it meets its expectations exceedingly well.
This attitude of "hurrr durrr crap car" because it's cheap is pretty poor tbh,
13 Nov 2006
Only you and Cookeh have used the term crap :)
Anyways let's not derail the thread.
