What's the go to Display Port cable?
18 May 2010
Hi,
My monitor didn't come with a Display Port cable, I borrowed one from work that would have come from dell 1080p 60hz monitor and is probably 5 years or more old. It seems to be fine but I might buy one to cherish forever and to cover future builds
Is it daft to buy one or is worth having a good display port cable?
Monitor is 1440p 155hz
Thanks
How far do you want the monitor to be from the PC? You're not going to have any issues with a standard 2 metre cable but you might find things get twitchy at 3+ metres. To get my 120 Hz 4K monitor working correctly with a longer cable I needed to go fibre-optic - £180 a pop. (Actually I purchased a 10m cable, but hey ho.)
Its just a standard setup so right next to it
