Don't the speed boosts usually go out to the lower tiers?
Generally speed uplift has been rolled out on a tier by tier basis, except where new tiers have been introduced.
500 service will require a new modem I thought, hard to see them throw out new kit for free.
https://www.ispreview.co.uk/index.p...in-media-business-prep-500mbps-broadband.htmlJust plain wrong.
I never meant they'd charge, there is an associated cost involved though between manufacturing, logistics, old kit reclamation etc.Virgin insist they own the modems so they'd be in a funny position trying to charge you for them. That doesn't rule out some sort of made up administration fee.
Why not? with better QoS it should be possible.Doubtful
What about these two?You’ll be ok as long as you’re not adding something like 50m of cable, and you use something designed for Virgin Media - triple or quad-screened with compression connectors. Not crimped or screwed on ones.
Has anyone tried moving the location of a Hub 3.0 using one of the cheapo extension cables off ebay?
No good, screw on connectors or just cheap looking cable.
Then can you link something that will do the job, please?No good, screw on connectors or just cheap looking cable.
Quoting from where I read the new router bit.
Our current expectation is that any new tier will still use Virgin Media’s existing EuroDOCSIS 3.0 based cable platform, rather than their future Gigabit capable DOCSIS 3.1 network. Virgin seem intent to ensure that every corner of their network is ready for 3.1 before flicking the switch (although a 3.1 capable router may arrive before the new network goes live) and the Project Lightning expansion could also still be taking precedence.
Are virgin home hub 3 modems ready to go with the faster newer 3.1 technology? if so why develop new hardware specifically for it. I am happy to be set straight here as I don't know enough about it. To reply 'just plain wrong' is not helpful.
Is that upload speed correct? I know that their upload speeds have always been a bit underwhelming, but that's pathetic.Upgrade day is here.
After:
