- 27 Mar 2003
So as title really. I have always been an air cooler user with my current cooler of choice being the be quiet! Dark Rock Pro 3 for my i7-5820K (2011-v3).
As I am embarking on a new case for the first time in 13+ years from my cooler master stacker STC 101 (which has served me well for the last 3 builds) for the Lian Li O11 Dynamic Razer Edition I though it would be time to refresh my case and have been debating for some time over another full tower (something like the be quiet! Dark Base Pro 900 v2) but ended up picking the Lian Li as I liked the look and the branding to go with my other Razer stuff.
So as this case version is based on the more water cooling focused design as opposed to the air cooling version I thought it would be a good time to also throw my hat into water cooling.
So with the seemingly never ending supply of videos on youtube I have been investigating either an AIO or going the more expert route of building a custom loop.
As my experience with water cooling is next to zero I feel that an AIO is probably the way to go but which one? As this will be only cooling the CPU and not the GPU I feel that maybe a 360 rad solution is probably overkill for me but as I plan to upgrade from my current cpu to a new intel one at some point in the next 12 - 18 months I wonder if getting a 360 rad would be a better "futureproof" solution. Plus I'm not really planning on doing any overclocking.
If I did go down the custom loop route how easy are they to setup, maintain etc. I think I have looked at too many videos on the subject and just confused myself with all the various bits and pieces that are required for a build.
As my PC is on 24/7 I do need to ensure that I have reliable parts (I know things can fail) and as much minimal servicing as possible.
Although price for a solution isn't a "major" issue I don't want to spend money needlessly and would like to invest in something that will ideally last me several years.
