OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
In awe at the size of this absolute unit... A gorgeous monitor with great features.
49-inch 32:9 (3840 x 1080) super ultra-wide HDR gaming monitor HDR with 144Hz refresh rate for super-smooth gaming visuals
High Dynamic Range (HDR) technology with DCI-P3 90% professional color gamut delivers contrast and color performance that meets DisplayHDR™ 400 certification
Radeon™ FreeSync 2 HDR technology provides buttery-smooth gameplay, low latency, and better brightness and contrast
Shadow Boost enhances image details in dark areas, brightening scenes without over-exposing bright areas
Multiple HDR modes allows users to adjust settings based on usage such as gaming, content creation or video display
Pre-order is open now, stock should be landing in approx 2 weeks!
ASUS XG49VQ ROG STRIX 49" 3840x1080 VA 144Hz HDR 400 FreeSync 2 Ultra-Wide Gaming Monitor @ £999.95 inc VAT
ASUS ROG Strix XG49VQ, 49" Display Size, 3840x1080 Resolution, 144Hz Refresh Rate, FreeSync 2 HDR, DisplayHDR 400, 3000:1 Contrast Ratio, 1800R Curve
Only £999.95 inc VAT.
ORDER NOW
GO BEYOND ULTRA-WIDE
ROG Strix XG49VQ is a super ultra-wide 49-inch gaming monitor with a smooth 144Hz refresh rate that offers the ultimate immersive gaming experience. It features Radeon™ FreeSync 2 HDR, and High Dynamic Range (HDR) technology with DCI-P3 90% professional color gamut coverage and DisplayHDR™ 400 certification.
EXPERIENCE THE SUPER ULTRA-WIDE
The 49-inch ROG Strix XG49VQ gaming monitor with 1800R curvature delivers the ultimate immersive gaming experience and extra flexibility for multitasking. With a 32:9 aspect ratio, the super ultra-wide display provides the same viewing area as two side-by-side 27-inch monitors without a gap and bezel getting in the way of your view.
FAST 144HZ REFRESH RATE
ROG Strix XG49VQ offers an ultrafast 144Hz refresh rate, ensuring that even the fastest-paced games played at the highest visual settings remain buttery-smooth and completely lag-free.
RADEON FREESYNC™ 2 HDR FOR SMOOTH GAMEPLAY
ROG Strix XG49VQ features FreeSync™ 2 HDR technology that delivers buttery-smooth visuals with low latency and better brightness and contrast. FreeSync 2 stipulates low-latency processing for both standard and HDR content, eliminating the input lag typically associated with HDR content.
HIGH DYNAMIC RANGE (HDR) WITH DCI-P3 90% AND DISPLAYHDR™ 400
To deliver the best HDR experience, ROG tests every monitor before it ships to ensure it passes DisplayHDR™ 400 certification. To meet this standard, the peak luminance of ROG Strix XG49VQ is 450 cd/m2 which is 50% higher than typical standard dynamic range displays. XG49VQ also delivers DCI-P3 90% color gamut and contrast performance.
*The data is from https://displayhdr.org/
PICTURE-BY-PICTURE
With its super-ultra-wide screen, multiple inputs and picture-by-picture support, ROG Strix XG49VQ lets you watch up to three content sources at the same time, so you can enjoy better gaming experiences, such as playing Xbox One or PS4 Pro games, while watching Twitch streams on your PC.
PICTURE BY PICTURE HOTKEYS
With convenient hot keys, ROG Strix XG49VQ lets you quickly and easily display different video sources side by side, and manually adjusts the layout for the best onscreen fit.
SHADOW BOOST TECHNOLOGY
ASUS Shadow Boost technology clarifies dark areas of the game world without overexposing brighter areas, improving overall viewing while also making it easier to spot enemies hidden in dark areas of the map.
MULTIPLE HDR MODES
Now you can choose from multiple HDR modes in order to adjust monitor HDR performance based on the current scenario.
GAMEPLUS TECHNOLOGY
A crosshair overlay provides four different crosshair options, so you can select the one that best suits the shooter you're currently playing.
The ASUS-exclusive, integrated GamePlus hotkey offers in-game enhancements that help you get more out of your game.This function is co-developed with input from pro gamers, allowing them to practice and improve their gaming skills.
ROBUST CONNECTIVITY
ROG Strix XG49VQ offers a wide selection of connectivity options, including DisplayPort 1.2,Two HDMI and two USB 3.0 ports.
ULTRA-LOW BLUE LIGHT TECHNOLOGY
ROG Strix XG49VQ comes with TÜV Rheinland-certified ASUS Ultra-low Blue Light filters to protect eyes and prevent strain from harmful blue light. Select from four different filter settings via the OSD menu or by using the five-way joystick.
FLICKER-FREE TECHNOLOGY
ROG Strix XG49VQ reduces on-screen flicker to minimize eye strain, providing a more comfortable gaming experience.
ERGONOMIC DESIGN
ROG Strix XG49VQ features a stand that's designed to be ergonomic. It offers extensive swivel, tilt and height adjustments to ensure that your ideal viewing angle is easy to achieve.
Swivel (+16o ~ -16o)
Height Adjustment : 0 ~ 120 mm
Tilt : +20o ~ -5o
Specification
Display
Panel Size: Super ultra-wide 49" (124.46cm) 32:9
Panel Type : VA
True Resolution : 3840x1080
Display Viewing Area(HxV) : 1195.8 x 336.3 mm
Display SurfaceNon-glare
Pixel Pitch : 0.311mm
Brightness : 450 cd/? (Typical)
Contrast Ratio : 3000 :1 (Typical)
Viewing Angle (CR?10) : 178°(H)/178°(V)
Response Time : 4ms (Gray to Gray)
Display Colors : 16.7M
Flicker free
Curved Panel : 1800R
HDR (High Dynamic Range) Support : Yes
Refresh Rate(max) : 144Hz
Video Feature
GamePlus(modes) : Yes (Crosshair/Timer/FPS Counter/Display Alignment)
Picture-by-Picture : Yes
Low Blue Light : Yes
HDCP support : Yes
GameVisual :8 Modes(Scenery/Racing/Cinema/RTS/RPG/sRGB Modes/MOBA Mode/User Mode)
Display Widget
GameFast Input technology
Shadow Boost
Audio Features
Stereo Speakers : 5W x 2 Stereo RMS
Convenient Hotkey
GamePlus
5-way OSD Navigation Joystick
GameVisual
I/O Ports
Signal Input : HDMI(v2.0) x2, DisplayPort 1.2
Earphone jack : 3.5mm Mini-Jack
USB Port(s) : 2.0x2
USB upstream : USB3.0 Type-B x1
Signal Frequency
Digital Signal Frequency : 30 ~167 KHz (H) /48 ~144 Hz(V)
Power Consumption
Power Consumption: Power Saving Mode: <0.5W
Power Off Mode: <0.5W
Voltage : 100-240V, 50 / 60Hz
Mechanical Design
Chassis Colors : Black
Tilt : +20°~-5°
Swivel : -16°~+16°
Height Adjustment : 0~120 mm
VESA Wall Mounting : 100x100mm
Security
Kensington lock
Dimensions
Phys. Dimension with Stand (WxHxD): 1193.33 x 529.10 x 344.74 mm
Phys. Dimension without Stand (WxHxD): 1193.33 x 369.7x 344.74 mm
Box Dimension (WxHxD): 1308 x 484 x 370 mm
Weight
Net Weight : 13.3kg; Gross Weight: 20.9 kg
Accessories
Power cord
Power adapter
DisplayPort cable
USB cable
Quick start guide
HDMI cable
Warranty Card
Compliance and Standards
BSMI, CB, CCC, CE, CEL level , CU, ErP, FCC, J-MOSS, KCC, PSE, RoHS, UL/cUL, VCCI, WEEE, WHQL (Windows 10, Windows 8.1, Windows 7), MEPS, RCM, TUV Flicker-free , KC , eStandby, TUV Low Blue Light, PC recycle, JM
Note
*measuring a screen brightness of 200 nits without audio/ USB/ Card reader connection
ORDER NOW
PICTURE-BY-PICTURE
MULTIPLE HDR MODES
GAMEPLUS TECHNOLOGY
ROBUST CONNECTIVITY
ERGONOMIC DESIGN
Tilt : +20o ~ -5o
Specification
Display
Panel Type : VA
Flicker free
Video Feature
HDCP support : Yes
Display Widget
Shadow Boost
Audio Features
Convenient Hotkey
GamePlus
GameVisual
I/O Ports
USB Port(s) : 2.0x2
Signal Frequency
Power Consumption
Mechanical Design
Tilt : +20°~-5°
Swivel : -16°~+16°
Security
Kensington lock
Dimensions
Weight
Accessories
Power cord
Power adapter
DisplayPort cable
USB cable
Quick start guide
HDMI cable
Warranty Card
Note
