1080p build question
15 Jan 2019
Hello there, I'm looking to upgrade my old rig (GTX 770 old) to something a wee bit more modern. The purpose of the system is mainly for 1080p gaming for the next few years. Anyway, this is the system:
CPU: Ryzen 5 2600
Motherboard: Gigabyte - B450 I AORUS PRO WIFI Mini ITX
GPU: GTX 1660 TI (or RX Vega 56 or RTX 2060 ???)
RAM: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-2666
SSD: Kingston - A400 480 GB 2.5"
PSU: Cooler Master - MasterWatt 550 W 80+ Bronze Certified Semi-Modular ATX
Case: Thermaltake - Core V1 Mini ITX
Monitor: AOC - G2260VWQ6 21.5" 1920x1080 75 Hz
A couple of things I just want to add:
My budget is around £850 although I'm willing to go over.
I'm unsure about the GPU. I've seen a couple of Vega 56s floating around the 1660 Ti price and at the same time I'm tempted to shell out extra £70 for a RTX 2060. The idea here is for the GPU to hold out for a couple of years, so I'm not sure if the 1660 is the right choice. Although I prefer Nvidia GPUs (Gefore experience, shadowplay etc) the Vega is making me wonder.
Cheers!
gtx 1660ti would keep you in budget.
Head up, ryzen 2700 is going for £205 on other sites!!!!
BB CODE
My basket at Overclockers UK:
Total: £859.15 (includes shipping: £12.30)
with VEGA 56, have to look for a 2 slot design to fit in 90% of ITX cases.
worth having a look at this!
https://bit-tech.net/reviews/tech/cases/metallicgear-neo-g-mini-review/1/
£70 and supports triple slot GPUs! Vega pulse is 2.3 slot design
Total: £849.04 (includes shipping: £11.10)​
freesync and g-sync combo monitor looking at £199
https://www.overclockers.co.uk/aoc-...ync-lcd-gaming-monitor-hdmi-dp-mo-04v-ao.html
Would you not be better off getting a second hand 980ti? It would cost a lot less and would afford you the ability to play at a higher resolution in the future, should you desire. Also, I'd be more inclined to get a 650+ EVGA Supernova PSU; having a little more than required is better than finding you don't have sufficient.
https://www.overclockers.co.uk/ante...plus-gold-modular-power-supply-ca-24n-an.html
£15-20 cheaper
980ti your running with no warranty as well , unless finding a gtx 1070ti for a good price and might get a year in there
