- 8 Jan 2007
- London & Dubai
Just about ready to order all my WC kit. Would like for some experienced members on here to give my list the once over.
Going to be cooling a i9-9900K & an RTX 2080Ti, all housed in a Lian-Li O11 Dynamic.
Rads are HWLabs Black Ice 360 SR2 & HWLabs Black Ice 360 GTS
Is there anything I should add or change?
My basket at Overclockers UK:
- 1 x EK Water Blocks EK-RES X3 - TUBE 150 (104mm)= £11.99
- 1 x EK Water Blocks EK-UNI Pump Bracket (120mm FAN) Vertical= £12.95
- 1 x EK Water Blocks EK-XRES 100 DDC 3.2 PWM Elite (incl. pump)= £124.99
- 1 x EK Water Blocks EK-Velocity RGB Intel CPU Water Block - Nickel + Plexi= £79.99
- 1 x Monsoon Hardline Pro Heatgun UK Version= £15.95
- 1 x XSPC PETG Chamfer Tool= £3.95
- 1 x Bitspower Metal Tubing Cutting Tool= £8.99
- 1 x EK Water Blocks EK-AF Angled 2 × 45 Degrees G1 / 4 inch - Black Nickel= £8.99
- 12 x XSPC G1/4" Stop Plug - (Black Chrome) V2= £1.49
- 5 x XSPC G1/4" 90° Rotary Fitting (Black Chrome)= £4.99
- 4 x XSPC PETG Tubing 14/10mm 2x0.5m (Clear)= £4.99
- 1 x XSPC G1/4" to 14mm Rigid Tubing Triple Seal Fittings - (Black Chrome) - 8 Pack= £28.99
- 4 x XSPC G1/4" to 14mm Rigid Tubing Triple Seal Fitting - (Black Chrome)= £3.95
- 1 x XSPC Ball Valve (Black Chrome)= £8.99
- 1 x XSPC G1/4" 4 Way Fitting (Black Chrome)= £4.49
- 2 x XSPC G1/4" Male to Female Rotary Fitting (Black Chrome)= £2.99
- 2 x XSPC G1/4" 5mm Male to Male Fitting (Black Chrome)= £1.99
- 1 x Monsoon Hardline Pro Measuring Kit - Universal= £10.99
- 1 x XSPC Heavy Duty Hose Cutter (0-25mm)= £6.95
- 1 x XSPC PETG Bending Rubber= £2.99
- 1 x XSPC PETG Easy Bending Tool= £6.95
- 1 x XSPC Razor Neo RTX 2080 Ti RGB Tempered Glass Graphics Card Water Block - Black Chrome= £124.99
Total: £562.79 (includes shipping: £11.10)
£5
(incl. VAT)
