Hi All,
I am looking for some thoughts on RAM upgrade options,
I currently have 2x8GB G-Skill 3200CL15 single rank with Samsung B-Die (F4-3200C15D-16GTZ) with a 6700k in a Z270 Gaming 9.
I mainly use this PC for gaming but I also do some 3D CAD (which uses quite a lot of RAM). I have seen the usage easily get upto 14-15GB so I am looking to add some more RAM to get 32GB.
I am finding it difficult to get a second set of memory that match my current set without getting them from the USA, I hope it is ok to mention but Newegg have some although they are a different colour.
An extra complication would be that I am thinking that I will upgrade to the Ryzen 3700X based on the leaks which I hope are correct, or I would consider the 9900K if the price came down a bit.
I understand that 3200 and CL 15 aren't really pushing the overclocks this is just the XMP and I run what I think is a save OC on the CPU 4.5 at 1.3v on my 6700k
what are your thoughts on getting selling my current set and getting a new 2x16GB set vs getting another two sticks from the USA for a 4x8GB setup. it is about £55 cheaper to get the second two sticks from the USA?
Thanks for your help
