OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Hi guys,
Pulled the MSI Monitor range off our system for you to peruse. We've added 6 new models including 32" and 34" panels. All apart from the g-sync NXG251R (flat panel and 240Hz) are curved, FreeSync and offer 144Hz refresh rate.
C models are curved, Q models are QHD and R models are height adjustable.
Check them all out below!
MSI Oculux NXG251R 25" 1920x1080 TN G-Sync 240Hz 1ms Widescreen Gaming Monitor @ £568.99 inc VAT
MSI Oculux NXG251R, 25" Display Size, 1920x1080 Display resolution, 100M:1 Dynamic Contrast Ratio, TN Panel Type, G-Sync, 240Hz Refresh Rate, 1ms Response Time, Widescreen Gaming Monitor
Only £568.99 inc VAT.
ORDER NOW
MSI Optix MAG341CQ 34" 3440x1440 VA FreeSync 100Hz Curved Widescreen Gaming Monitor @ £539.95 inc VAT
MSI Optix MAG341CQ, 34" Display Size, VA Panel Type, 100Hz Refresh Rate, 100M:1 Contrast Ration, Curved, Widescreen, Gaming Monitor
Only £539.95 inc VAT.
ORDER NOW
MSI Optix MAG321CQR 31.5" 2560x1440 VA FreeSync 144Hz Curved Widescreen Gaming Monitor @ £448.99 inc VAT
MSI Optix MAG321CQR, 31.5" Screen Size, 2560x1440 Display Resolution, 100M Dynamic Contrast, VA Panel Type, 144Hz Refresh Rate, Curved, Widescreen Gaming Monitor
Only £448.99 inc VAT.
ORDER NOW
MSI Optix MAG271CQR 27" 2560x1440 VA FreeSync 144Hz 1ms Curved Widescreen Gaming Monitor @ £399.95 inc VAT
MSI Optix MAG271CQR, 2560x1440 Resolution, VA Panel Type, 100M:1 Contrast Ratio, 144Hz Refresh Rate, 1Ms Response Time, Curved, Widescreen Gaming Monitor
Only £399.95 inc VAT.
ORDER NOW
MSI Optix MAG271CR 27" 1920x1080 VA FreeSync 144Hz Curved Widescreen Gaming Monitor @ £298.99 inc VAT
MSI Optix MAG271CR, 27" Display Size, 1920x1080 Resolution, DCR Dynamic Contrast Ratio 100M:1 VA Panel Type, FreeSync, 144Hz Refresh Rate, Curved, Widescreen Gaming Monitor
Only £298.99 inc VAT.
ORDER NOW
MSI Optix MAG241CR 24" 1920x1080 VA FreeSync 144Hz Curved Widescreen Gaming Monitor @ £269.99 inc VAT
MSI Optix MAG241CR, 24" Display Size, 1920x1080 Display Resolution, DCR Dynamic Contrast Ratio 100M:1, VA Panel Type, FreeSync, 144Hz Refresh Rate, Curved, Widescreen Gaming Monitor
Only £269.99 inc VAT.
ORDER NOW
MSI Optix MAG27CQ 27" 2560x1440 VA FREESYNC 144Hz 1ms Curved Widescreen Gaming Monitor @ £399.95 inc VAT
S15-000701G-HH5, 2560x1440 Resolution, 50M:1 Contrast Ratio, 1ms Response Time, 250 cd/m2 Brightness, 1x HDMI Input, 1x DP, 1x DVI, Freesync, 144Hz Native, 1800R Curve, 2yr Warranty
ORDER NOW
MSI Optix MPG27CQ 27" 2560x1440 VA FREESYNC 144Hz 1ms Curved Widescreen Gaming Monitor @ £518.99 inc VAT
9S6-3FA31T-017, 2560x1440 Resolution, 50M:1 Contrast Ratio, 1ms Response Time, 400 cd/m2 Brightness, 1x HDMI Input, 1x DP, 1x DVI, Freesync, 144Hz Native, 1800R Curve, 2yr Warranty
Only £518.99 inc VAT.
ORDER NOW
MSI Optix MAG27C 27" 1920x1080 VA FREESYNC 144Hz 1ms Curved Widescreen Gaming Monitor @ £279.95 inc VAT
S15-0003095-HH5, 1920x1080 Resolution, 10M:1 Contrast Ratio, 1ms Response Time, 250 cd/m2 Brightness, 1x HDMI Input, 1x DP, 1x DVI, Freesync, 144Hz Native, 1800R Curve, 2yr Warranty
Only £279.95 inc VAT.
ORDER NOW
MSI Optix MPG27C 27" 1920x1080 VA FREESYNC 144Hz 1ms Curved Widescreen Gaming Monitor @ £349.99 inc VAT
9S6-3FA41T-012, 1920x1080 Resolution, 50M:1 Contrast Ratio, 1ms Response Time, 250 cd/m2 Brightness, 1x HDMI Input, 1x DP, 1x DVI, Freesync, 144Hz Native, 1800R Curve, 2yr Warranty
Only £349.99 inc VAT.
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
