CUE Problem
9 Mar 2019
Hey guys,
I have just installed Windows 7 and now I can't get my H115i RGB Plat to show in CUE software, I have tried all sorts but it won't show. The link software also doesn't work with it and tells me "the CUE software handles the AIO". Now I have checked the drivers and they are all upto date, the fans are all on quiet and can't be heard, but when gaming they will need to go faster obviously. I am on the latest drivers. What can I do?
Actually they shouldn't. Pretty much the main point of water coolers is that they are damn quiet and offer better temperatures.
Have you checked what your temps are to see if you actually want the fans and pump to ramp up to higher speeds?
Suggest plugging the. Into mobo and letting them control it
Motherboard has much more accurate fan control than any controller as it has a direct link to the cpu temperature sensors ect, you can set custom curves and such in the bios that will ramp the fans up during intense loads.
temps are ok but I need to be able to control the fans.
If the temps are okay what do you need the fan control for ? just for the sake of lower temperatures?
I don't want to have to use the Motherboard fans fan to control them, this was one of the reasons I got the commander.
