Hi all,
I already have a main gaming rig for FPS and other titles, but where it is there isn't enough room for a proper chair/wheel setup. I have another room which is used for my homelab stuff and I am wanting to build a second system in there. It'll also double up as a workstation and ESXi host.
I'm looking for a Ryzen based system, mainly as my main rig is Intel and I fancy a change. I guess having an NVidia GPU in my main rig I might fancy an AMD GPU as well.
Spec wise it needs to be able to play Assetto Corsa and Project Cars 2 at 120 fps and for the start it'll be driving a 1440p panel.
Since it'll be dual booting I would want 8c/16t minimum and 32GB of RAM.
Finally, I'll be wanting a dual port Intel 10 Gbit SFP+ network adaptor to connect into my switch, so the motherboard and case should be able to accommodate the GPU as well as another card.
Any deals around that meets this? What sort of price would I be looking at? Thanks!
