it isn't well ventilated. but up to you. your money.I think I prefer the Corsair case and it's slightly cheaper so I'll stick with that.
yes. intel turboboost allows the cpu to run at higher frequencies if it doesn't reach thermal limits.Is the cooler really worth the additional cost on the basis I'm unlikely to overclock?
it won't run. no ram.Thoughts on this?
i don't know why you'd want to split the budget if you need/are buying a whole new system. you should consider it (tower and peripherals) holistically.This seems to fit between the two and still keeps the PC under £1500.
it won't run. no ram.![]()
not at the price point. to get a solid case, you'd have to compromise on noise or thermals.Fair enough, any other cases you would recommend? I'd prefer something compact and understated. No glass would be my preference and as quiet as possible.
just name your total budget and one of us will try and get the best value build.Point taken I'm just still very undecided on peripherals.
you've already practically decided what peripherals you want, so i can't be bothered to change your mind. so just stuck with what you went for.
left a bit of budget for your headset and windows.
My basket at Overclockers UK:
- 1 x LG 34GK950F 34" 3440x1440 NANO IPS FREESYNC HDR 144Hz 1ms Curved Widescreen LED Monitor= £1,099.99
- 1 x Intel Core i7-9700K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - OEM= £349.99
- 1 x Gigabyte Z390 Aorus Elite Intel Z390 (Socket 1151) DDR4 ATX Motherboard= £179.99
- 1 x MSI GeForce RTX 2080 Ventus 8192MB GDDR6 PCI-Express Graphics Card= £659.99
- 1 x Corsair Vengeance LPX 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Black (CMK16GX4M2D30= £98.99
- 1 x Antec EarthWatts Gold Pro 650W 80 Plus Gold Modular Power Supply= £79.99
- 1 x WD Blue 3D NAND 1TB 2.5" SATA 6Gbps Solid State Drive (WDS100T2B0A)= £109.99
- 1 x be quiet! Dark Rock Pro 4 CPU Cooler= £73.99
- 1 x Fractal Design Define R6 Midi Tower Case - Gunmetal Grey= £124.99
- 1 x OcUK Mega Mat XXL Premium Elite Tactical Gaming Surface= £16.99
- 1 x Logitech G305 Lightspeed Next-Generation Wireless USB Optical Gaming Mouse (910-005283)= £44.99
- 1 x Logitech G213 Prodigy RGB Gaming Keyboard (920-008091)= £49.99
yesthat should last me a number of years
no. unfortunately with intel, you're on a dead-end platform. the only scope you have to upgrade to, is to the 9900k. see my previous post (quoted below for reference).give scope to upgrade
with respect to:
1) CPU:
intel has the single-core lead due to its clockspeed advantage. as @orbitalwalsh has said, an overclocked intel would be better for gaming workloads. (intel 9900k vs ryzen 2700x = ~12% in favour of intel).
however, as intel likes to change its CPU sockets frequently, you're (potentially) buying into a dead end route. though granted the future upgrade options you have are the 9700k and the 9900k.
whereas with AMD, they're going to support their AM4 platform until 2020. what this means is that ryzen 3000 (which is going to be released in 3-4 months) and potentially ryzen 4000 are going to be supported. now with ryzen 3000 series, AMD are gunning for intel's single-core lead and also piling on the cores on their CPU - so expect to see a 16 core chip for ryzen 3000.
better VRMs. will handle a 9900k's power drawWhat is the reason for this mobo over say the gaming version that's slightly cheaper. Happy to pay the extra if it's worth it just thinking it may be overkill for me?
no. define r6 comes with 3 fans preinstalled. hence you don't need to get any extra ones.Also, is it worth me getting adding the two case fans?
Thanks again for the help. The AMD spec does come out a bit cheaper..
I'll have a think tomorrow and make a decision.
Thanks
- 1 x Sapphire Radeon RX VEGA VII 16GB HBM2 PCI-Express Graphics Card= £649.99
- 1 x MSI B450 GAMING PRO CARBON AC (Socket AM4) DDR4 ATX Motherboard= £119.99
- 1 x AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail= £329.99
That looks freakishly similar to my original specThanks again for the help. The AMD spec does come out a bit cheaper..
That is indeed true. However, it is well recognised that nvme does not give significant real world gains outside of benchmarks for uses such as gaming.The WD blue SSD's are slow in comparison to an M.2 NVME drive.
