- 19 Feb 2007
- Northampton
Thought I'd make a dedicated post rather than it getting lost in the Radeon VII thread.
As a few people are a ware the cooling plate on the R7's heat sink is very concave, Meaning quite a lot of it simply does not make contact with the GPU die itself hence the 110'c junction temp, I had to remedy mine by getting some 400, 800 and then 2000 grit sandpaper wrapped around a flat block of metal to make it flat, Temps went down a tremendous amount as the plate is now actually making contact with the die.
So that got me thinking, I'm pretty sure not everyone is going to break out the sand paper on a £700 card, How long will these cards last at such extreme temps on the junction ? 110'c prior to overclocking is hella high.
