B450 AORUS ELITE - Motherboard mounts
10 Apr 2015
Hungerford, UK, Earth
I helped a mate build his PC, he bought the motherboard below. Just a warning to anyone, there are no mounting holes on the right hand side of this board, and the middle offset mount doesnt line up with any case mounting positions, even if it did, you still have to make sure you firmly grip the motherboard before plugging the mobo power and the SATA cables, the Pro version is slightly wider and has the extra mounts
My basket at Overclockers UK:
Total: £102.49 (includes shipping: £10.50)​
she's got more holes then a *insert pun*
IO installed plate means you've got to give it some wellie to the rear of the case to line up holes
mounted fine in dynamic case
thats not the same motherboard (or at least Revision) look a the one i linked to it doesnt have the last set of holes as your boards do
ah crumbs , your site. by 10mm
middle ones should mount up fine as itx/matx standard though- theres extra one in the middle row under the ram that would require mobo stand to be moved if its able to though
