young and old pc build
19 Mar 2019
ryzen 2600 cpu
b450 pro carbon motherboard
16 gb ddr4 3000mhz memory
600 power supply
ideas for graphic card.
this is a build for my 12yo g/grandson.
can change any part on advice.
i am a 75yo and we are going to build this with visuals from you tube.
1 Dec 2015
ryzen 2600 cpu
600 power supply
Aorus b450 + ryzen 2600 + gigabyte 700w psu + The Division game free for £255
BU-GBT-01-Bundle-Ryzen-5-2600-Gigabyte-B450-AO_2496239.html
My basket at Overclockers UK:
Total: £321.62 (includes shipping: £11.70)
2 free games with rx 570 , all for £580 :)
depending on your budget could push higher GPU or SSD or lower to 8gb ram
Man of Honour
26 May 2012
what aorus mobo do you recommend-the pro-elite-m-wifi,to try and future proof it for a few years
they all have the same voltage regulation, so much of a muchness, really.
i'd just get the cheapest one.
the combo that @orbitalwalsh linked is good value. i'd suggest getting that. [edit: out of stock now]
if you need a wifi card, then just get an add-on card.
1 Dec 2015
CCL has it in stock :)
product/275044/NoMfgCode/Motherboards/Gigabyte-B450-AORUS-Pro-Bundle-with-700W-PSU-and-AMD-Ryzen-5-2600-CPU/MBD2468B/
intel with wifi- but as you can see, not as good as going with that bundle and products listed above for £580 plus 3 free games instead of 2
Total: £653.19 (includes shipping: £12.30)​
OP
19 Mar 2019
thanks for video,will watch this i think i have reached my limit on spend.one more thing what power supply and rating.thanks in advance
