Lian Li PC-011 WGX ROG v2
6 Aug 2010
Suffolk
I've seen a few pictures of the Lian Li PC-011 WGX ROG v2 at CES 2019, it didn't look a "prototype" case to me. I was looking to do a build in the PC-011 Dynamic, but this new ROG version is perfect for my watercooling needs!
When do you think we are likely to hear of a release date as I'll certainly be pre ordering this case!
What does everyone think of it? below are some articles that I can find on it:
https://www.techpowerup.com/251382/...-prototype-liquid-cooler-and-more-at-ces-2019
https://ocaholic.ch/modules/news/article.php?storyid=18417
https://www.guru3d.com/news-story/lian-li-readies-showcases-new-products-and-collaboration.html
28 Sep 2018
That’s the case I’m waiting on to replace my HafX finally. The AIO will take care of the cpu while the GPU cooling can match or exceed the HafX in a modern layout.
The extra 2 usb in the front is a major bonus for me since sim racing rigs need a lot of USB ports. Sounds like the improvements will be well worth it.
24 Aug 2013
Lincolnshire
Would be nice to hear something official, as that's a case i'll certainly be pre ordering!
Same! I currently have the original wgx and it is a very nice case but as most other cases it isn’t without some flaws or limitations. Side panels being a pain to fit, prone to falling off when installing/removing etc.
This one seems to address those issues as well as improving upon the design as well.
Anyone have any dates etc as I’ll be looking to preorder one.
24 Mar 2019
So I am holding off picking up the Lian Li 0-11 Dynamic "standard Edition" because I am keen on picking up the ROG v2 in the coming month. My question is it really worth it though? Is there enough to wait and pick this case up over the standard one?
31 May 2014
Really depends on what your planned build is, I have the dynamic but am wanting to do a custom loop but there are some real restrictions on the kit you can use so for me, if a bigger version resolves the issues then its worth it
1 Dec 2015
https://wccftech.com/lian-li-shows-off-new-cases-and-fans-at-ces-2019/
better pictures
if your intending to mound dual GPUs are GPU + AIC then it looks great a long with ability to house 160mm CPU cooler.
Rads at the bottom will be far more easier now to set up and not clash .
Personally I wished they just did what other vendors do an attach Vertical Brackets to the rear of the case next to the horizontal pci's - and just allow users to use kits such as cooler master or phanteks for single or dual set ups. looks Untidy
31 Mar 2019
For anyone wondering I emailed Lian Li and got a response:
Mar 14, 2019, 8:34 PM
Hi
The case will available in June .
-----Original Message-----
Sent: Friday, March 15, 2019 9:48 AM
To: [email protected]
Subject: USA - Message from website -
Model Name:lian li pc-o11 wgx rog v2
Message Body:
Hello! I was wondering if there was an estimated release date for the
lian li pc-o11 wgx rog v2 case.
I'm very excited to purchase this case for my next build. Do you
happen to have a mailing list I can sign up for?
