2 x Vega VIIs?>snip<
It would need part of Sellafield and reactant coolant for 2 Vega VIIs.And a nuclear power plant
+ One iceberg
2 x Vega VIIs?
+ One iceberg
Yes, but they do sli.If I remember correctly, someone proposed 2 x 2080 Ti which are as power hungry or even more power hungry?
Vega VIIs have no crossfire support.
No, but why would i?Have you tried and what's the message when two GPUs are enabled in the motherboard?
You secretly craved the *more power*.Me, was pure jokes and highlighted would be made to buy!
Me, was pure jokes and highlighted would be made to buy ! Single card 90% of the time for gaming . Only worth if doing workloads having multiple cards![]()
Crossfire works. Don't know how exactly AMD would not support Vega VII, when the original Vega 64 supports it pretty well: https://www.reddit.com/r/Amd/comments/8ylz2i/vega_64_crossfire_scaling_testing_in_24_games_5/
50% on average, which is pretty good, when taking into account it's tested across 24 games/applications and in some it doesn't scale, in others it scales up to 103.1%!
You don't mean that - this is a must if you have the room. It will be for me when the kids have grown up and left home. I'm not allowed to commandeer another room until then. Stupid guests and their need for a room... :/I even listed 2x 4k monitors to go with one OP had as a far fetched idea, though fun, useless
It's just an opinion, @4K8KW10 (that was hard to type) on a pad - you're still entitled to yours, doesn't make your requirements, or even the technology, wrong/weird. But wouldn't you ideally prefer a single card solution?This is extremely weirdAm I the only person on this sad Planet who has always been positive towards Crossfire and supporting it?
Actually supporting Crossfire is easier than designing new GPU with the same corresponding scaling![]()
Hallo,
Order this:
My basket at Overclockers UK:
- 1 x Seasonic Prime Platinum 1300W 80 Plus Platinum Modular Power Supply= £264.95
- 1 x Asrock Radeon RX VEGA VII Phantom Gaming X 16GB HBM2 PCI-Express Graphics Card= £649.99
- 1 x Sapphire Radeon RX VEGA VII 16GB HBM2 PCI-Express Graphics Card= £649.99
- 1 x G.Skill Trident Z 32GB (2x16GB) DDR4 PC4-28800C17 3600MHz Dual Channel Kit (F4-3600C17D-32GTZKW)= £349.99
- 1 x Asus ROG Crosshair VII Hero (Wi-Fi) AMD X470 (Socket AM4) DDR4 ATX Motherboard= £257.99
- 1 x Samsung 970 EVO Plus Polaris 1TB M.2 2280 PCI-e 3.0 x4 NVMe Solid State Drive= £239.99
- 1 x Samsung 2TB 860 EVO SSD 2.5" SATA 6Gbps 64 Layer 3D V-NAND Solid State Drive (MZ-76E2T0B/EU)= £278.99
- 1 x AMD Ryzen 7 Eight Core 2700X 4.35GHz (Socket AM4) Processor - Retail= £289.99
- 1 x be quiet! Silent Loop Superior Liquid CPU Cooler - 360mm= £149.99
- 1 x CoolerMaster Cosmos C700M RGB Full Tower Case - Black Tempered Glass= £419.99
- 1 x BenQ EW3270U 32" 3840x2160 4K VA 60Hz FreeSync Widescreen LED Monitor - Black/Red= £393.95
