The holstered talent on the chatterbox is worth it notebook than the actual gun, solid just to have equipped for other weapons.
Are you combining those stats with strained and berzerk? It is obscene damage when they both proc
Heads up, Agents! We're performing a quick server restart in 45 minutes. Expected downtime is approximately 30 minutes. The server restart will fix occasional server crashes. Thanks for your patience!
do they still drop on lower level but just not 100%? or is it 0%?
Can't remember other talents/attributes off the top of my head. I'm pretty sure I have the one where you get multiples of 2% damage on enemy kill for every 10k armour you have and I have 182k armour so the buff is pretty mental.
Will double check what the talent names are later on when I finish work
EDIT: the one I am on about is Unstoppable Force so I get a rough 36% extra weapon damage which seems to equate to about 20k on proc which makes sense as that's what the UMP.45 hits for and more so on Elites.
Shawrey
now the grind begins.sorry I meant lower control point levels.
so level 3 at wt4.
What's the most effective way to deal with those massively armoured dudes when taking objectives? I have a level 6 SDV rifle which is effective against most enemy grunts but hardly makes a dent in the big armoured dudes armour.
Meh, I'm barely getting 60 fps with everything on low...![]()
Are these the ones where you need to find their weak point, like the mission where you need to shoot the belt of the armoured mob?What's the most effective way to deal with those massively armoured dudes when taking objectives? I have a level 6 SDV rifle which is effective against most enemy grunts but hardly makes a dent in the big armoured dudes armour.
Cover + lmg for me. Also burn them, blow them up, use cooldowns, focus fire if in group.
Enemy armour damage & Damage to elites
Hi m8, can you elaborate on that? I'm an utter newbie at this, are those perks you need to build up or something?
Yea the one I joined only has 3 membersIs there a waiting list for either of the full squads?
Everyone I game with is in either of those and they are full, I bees loanlee.
