There are battery socket guns that will take them off with little effort. Dewalt or milwaukee have breakaway torques of >1600ncm-1
This looks like a dream for a diy mechanic, didn't realise you got battery operated ones, how does the power of this compare to an industry electric one?
https://www.amazon.co.uk/DeWalt-DCF899P2-GB-Cordless-Brushless-Batteries/dp/B00VXN829E
As above either a high torque gun or get a 3/4" breaker bar and a length of tube to go over it
You are 'supposed' to use impact sockets, but you can use regular high quality sockets every now and again. Also be aware that the impact gun in the link doesn't come with batteries & charger which is where the initial cost lies.I take it for something like this you can use any old extension bar and sockets?
https://www.amazon.co.uk/NoCry-20V-...ir+impact+gun&qid=1553945884&s=gateway&sr=8-3
1/2” square breaker bar, longer the better. You’ll also need A socket 30,32,34,triple square depending on what carThe big bolt that holds the driveshaft (or axel, whatever it is) in place. I've seen yt vids and they use the air gun but is there a hand held tool, I doubt you would get a socket bit that size for a standard rachet.
it doubles up as an impact driver, so even at home mine gets used weeklyThis looks like a dream for a diy mechanic, didn't realise you got battery operated ones, how does the power of this compare to an industry electric one?
They're still fairly expensive for seldom usage.
Mechanics are using these a lot though, they're just more convenient, my brother has three of them for his work.
