- 6 Jan 2013
- Rollergirl
Do you live in a caravan?
No, if I did I would just move the caravan.Do you live in a caravan?
Haha ha!Checkmate.
Lol, Sometime I think it would be easier if I did have a smaller family and/or not as close,Sounds like you need a smaller family and a bigger patio.
You know because no one has actually mentioned any markers
I dont think that will work with everything, like tools and such.Soldering iron.
ThanksYou know because no one has actually mentioned any markers I'll give you a couple of suggestions:
Black Sharpie (hard to get off but whiteboard marker will remove it from shiny surface)
Montana acrylic paint (graffiti) marker
Bank vault hidden below house.
it's mostly one or two people.I would suggest locking your doors or moving away. Sounds like a right set of chavs.
I would but I dont for the same reason I let it go and just tell them, its not worth the fight over a few quid.When they claim "this one is mine, I bought it after using yours"
Just borrow it and don't give it back. Say you bought a replacement.
Thanksi've said it above and i'll say it again - get a texpen - they write on oil and under water and if you want to get it off you have to use a sander.
Soldering iron.
it would work perfectly if every time you identified a 'family' thief you stuck the soldering iron right up their Khyber pass......I dont think that will work with everything, like tools and such.
Spray paint your tools and such pink?I dont think that will work with everything, like tools and such.
