windows ssd issue
27 Mar 2016
Bristolian living in Swindon
Hi all
so after some time ive finally got windows installed onto SSD... The Pc started up and I got to desktop, I then shut down the PC to see if all was ok on the start up.. It then goes into BIOS and does not show the SSD with the OS on and will then say Windows Error your PC needs to be repaired
any help appreciated, as I am at my wits end with this machine
Spec list - motherboard ?
Unplug and reseat all connections in to the ssd - re-seat motherboard sata connection too.
Disconnect all your other drives leaving only the SSD, and then clear the cmos.
Reboot back into BIOS - check for signs of life.
Did you get it working?
Sorry bud didn't realise you replied... mamaged to get it working... i literally unplugged all the connections and put them in again... also swapped out my sata cables for new ones and its done the trick... Cheers for that
