- 10 May 2012
- North London
The only thing I know my Son uses on hes Mobile is my Brother in law's Netflix
This is generally not a good idea. The router needs to be left on to find its optimum connection speed.
Hmm... just a thought, but if you switched it off, then the IP address would be assigned to someone else at the time.
Well I would be happy for it to be left on, but the wife likes things not to be left on/plugged in.
Get official confirmation from VM and show her.
Seems odd that they emailed you within 24 hours, usually it's a 3rd party that deals with the requests.
also when i login to my ASUS DSL-AC68U and i go to enter my password it tells me the its not a secure connection ? ie the " padlock" icon has a red line through it .
Who is downloading the 1973 film Westworld? Or is it the tv series?
What is the upshot of this letter? What is it asking?
The usual way that people end up getting these letters is with using torrent sites as your ip is exposed and you're technically uploading as well as downloading too.
If you turn your router off at night, then can you go and check your logs to see if it was active during those houses?
If the router was off then your connection wouldnt be active and VM should know this.
sounds like a genuine email as I've has a few in the past when I had to resort to the bay of buccaneers to find something that could not be found elsewhere. Usually only use private sites or newsgroups.
should be from '[email protected]'
How do the aggrieved party know your IP address was involved in this anyway?
