bathroom layout - sloping roof prevents shower
If you're going to have issues standing up to wee, you're also going to have issues standing up to have a shower, with the shower also tucked underneath the sloped roof? Albeit in a different corner?
Its very difficult to show the sloping roof in these layouts. Ive had another go here from a different angle.
I dunno, does this work? My main concern is how to fit a bath in that spot - i.e do I need to build a wall to back it on to, and to house the shower gubbins, if you see what I mean?
That's good .. space to dry yourself when you get out of shower, basin beneath window,
shower screen on top side, can pivot clockwise, at left end, to open up area when using as a bath
I have tried to improve the way the roof slope is visualised, this is the best i can do. You can see the red lines which represent the plane of the roof projected down to floor level.
So in this view you can see that there is a risk of needing to 'duck' under the roof line and around the glass to get into the walk in shower. If it was a bath there, you'd also need to step into the bath whilst ducking under the roof and around the glass. I am not sure whether the roof line will impede on the toilet here either.
One idea but what about turning it into a wet room? Might allow better use of the space? As you don't need to worry about the shower screen In the same way.
Exactly my thought.
Make room a wet room, refit bath, sink and toilet in same places.
Add a shower on the wall next to bath, add a simple short glass screen (floor to ceiling) next to door to stop any water going onto (assume) landing.
It looks to be big enough. A little water may get into/under bath, but shouldn't be a big issue.
in particular, having a sole bathroom as a wetroom, maybe problematic, plus, unless its massive, how do you stope encroach of water towards toilet pedestal/basin,
- the only folks I know who have one is for mobility problems.
