I need to drill some holes in the porcelain tiles in my shower but my existing drill is well past it's prime so I need a new one. It won't get loads of use so could you recommend a half decent drill and some bits which would do the job?
			Those drill bits seem cheap enough, I imagine that they’ll burn out when drilling porcelain anyway.
As for the drill, not sure really, maybe £100? Would that be enough for a half decent drill?
