I know this is quite a specialist subject, but just in case there are any roofers on here who may be able to offer some advice.
My ~1940s house still has its original roof and I'm looking to get it replaced. The houses on the estate are a mix of private and council but mine is the only one still wearing its original roof. The council replaced all of theirs around 20 years ago.
Fairly straight forward so far... only the roof structure is made out of steel, rather than timber. My roof is constructed of steel trusses and rafters with a metal grid fixed on top and then concrete tiles cemented directly to the frame. It looks fairly normal from the outside.
I've had a few people out to survey, one of them quoted me a ridiculous price which involved ripping out all of the steel and replacing it with a timber structure. The others have given similar opinions, to fix timber batons to the steel to build an additional structure allowing the use of felt and conventional tiles. My main concern is that they can't guarantee the height of the roof will match with the adjoining property, one of them even saying it could be as much as 150mm difference!
Intrigued to see what the council did with their properties, I had a look in my neighbours loft this morning.
Not quite what I was expecting to see, large sheets of possibly not very thick plywood screwed straight to the metal structure. I can only hope that there was a layer of felt between the tiles and the boards.
Would the work completed by the council pass currently building regs and should I be seeking building regs approval for the roof replacement given that there could be some changes to the structure of the roof?
