Some results using Ballistix Sport LT 3000Mhz (BLS8G4D30AESBK)
22 Sep 2009
I recently got two 8gb sticks of this ram for my Ryzen build and thought I would create this thread to see if others might have similar or better results tweaking them.
They 8Gbit Rev E Micron memory and are sold as 3000Mhz (15-16-16) 1.35v.
At the rated 1.35v they happily run at 3466Mhz (16-18-18), but by increasing the voltage to 1.4v I managed to tighten the timings quite a bit..
3466mhz 14-17-10-14-21
Also, but not memtest stable..
3600Mhz 14-17-10-17-28
If anyone else has these or similar memory please share your results..
OP
22 Sep 2009
TBF you could probable go more, i used to run 1.45v day to day and was told 1.5 is ok if you have air flow over it
I saw one of buildzoid's videos on youtube where he pushed crazy volts through this kit and I just thought ..wow!!
I'll see if I can get 3600mhz stable at cl14, sadly TRCDRD will not budge at all so that is as low as it will go..
