16 Apr 2019 at 12:18 #1 rhysduck rhysduck Soldato Joined 25 Oct 2009 Posts 6,728 Location Caerphilly Hi, Is there anything I can do to speed up the macbook? Since the last update it's been considerably slower than the previous update. Thanks
16 Apr 2019 at 15:02 #2 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,524 Location In the radio shack Do the obvious disk check through disk utility but the first thing I would do is install the latest Combo update.
16 Apr 2019 at 15:10 #3 MrRockliffe MrRockliffe Soldato Joined 14 Apr 2014 Posts 8,099 Location Hampshire What's the model number?
18 Apr 2019 at 18:59 #4 rhysduck rhysduck Soldato OP Joined 25 Oct 2009 Posts 6,728 Location Caerphilly MrRockliffe said: What's the model number? Click to expand... A1278 Feek said: Do the obvious disk check through disk utility but the first thing I would do is install the latest Combo update. Click to expand... How do I install the combo update please? Im on Mojave 10.14.4
18 Apr 2019 at 19:00 #5 MrRockliffe MrRockliffe Soldato Joined 14 Apr 2014 Posts 8,099 Location Hampshire rhysduck said: A1278 Click to expand... Is it a i series processor, or Core 2 Duo? My father has a 2009 Macbook Pro, and even after installing an SSD, it didn't speed up all that much :/
18 Apr 2019 at 19:03 #6 rhysduck rhysduck Soldato OP Joined 25 Oct 2009 Posts 6,728 Location Caerphilly MrRockliffe said: Is it a i series processor, or Core 2 Duo? My father has a 2009 Macbook Pro, and even after installing an SSD, it didn't speed up all that much :/ Click to expand... Its an i5 2.5Ghz with 4Gb RAM. Intel 4000 Gfx 1.5gb
18 Apr 2019 at 19:05 #7 MrRockliffe MrRockliffe Soldato Joined 14 Apr 2014 Posts 8,099 Location Hampshire rhysduck said: Its an i5 2.5Ghz with 4Gb RAM. Intel 4000 Gfx 1.5gb Click to expand... Doubling the RAM may help, along with installing an SSD if you haven't already
19 Apr 2019 at 07:00 #8 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,524 Location In the radio shack rhysduck said: How do I install the combo update please? Im on Mojave 10.14.4 Click to expand... Google “10.14.4 combo” then download and run it.
