- 18 May 2010
Hi,
Edit - Title is meant to read -
Gaming over WiFi for the next few months (How to make the best of a bad situation)
I'm currently using the built in WiFi connection of my MSI B450 Pro Carbon which is paired with the Virgin Media SH3
The router is downstairs, the PC upstairs, I get a decent connection and its fine for browsing and YouTube but when gaming I'm getting lag which is annoying especially when the Mrs is watching iPlayer etc
I cant run a cable because my PC wont be in the room its in for long, I'll need to move it to the master bedroom in a few months where I'll be able to run a cable to the loft to a switch and then a cable to the location where my PC will be.
I was wondering whats the best out of these temporary solutions bearing in mind I want to increase gaming performance -
1 - Buy a decent AP, disable the SH3 wireless and use the AP instead. Any suggestions on this one, is it worth it? The location will be the same and when my PC moves location I can move the AP into the loft plugged into the switch in which case, can I have the SH3 wireless re-enabled to serve downstairs and the AP upstairs so both wireless networks are available?
2 - Put the SH3 in modem mode and buy a better router, I'll probably need to do this at some point anyway to control what times children can access the internet when they are older but the eldest has just turned 3 so this could be some time off yet. Thoughts on this option please, is it worth it for improved gaming performance on WiFi considering it costs much more than an AP and wont serve its original purpose in a few months time? I keep reading about QOS and Mu-Mimo(?) but I dont know if this is marketing fluff or if its worth it
Edit - Another thing i've noticed is I have to keep disconnecting and reconnecting my desktop otherwise the connection speed is poor, disconnecting and reconnecting puts the speed back to normal, is this the SH3 or my desktop that could be doing this?
Thanks
Thanks
