- 18 May 2010
Hi,
I'm thinking of getting a cable run from the router in the front room, up the outside wall and into the loft where it will terminate to either a basic panel or some form of switch, from there a cable will run out down the outside walls and back in to the box room and my sons room.
Couple of things -
Does it get too hot in the loft for a switch and will it better to just use a patch panel? Is the switch just another point of failure to go up into the loft and have to restart it when its playing up?
Other than not looking particularly nice is there any issue having these cables running on the outside walls? Doing it this way prevents any need for plastering etc
Thanks
Chris
Couple of things -
Thanks
Chris
