I need spacers or gaskets + longer screws to mount my radiator
18 Oct 2002
Kent
I cant mount my radiator properly due to it being a multi-port design and i have no desire to physically mod my case.
I was wondering if someone could recommend some appropriate spacers/gaskets as well as slightly longer screws.
Thanks
Assuming you have screws that reach through fans into the rad just mount the fans between the case and the radiator. The difference between having fans in pull rather than push is minimal.
That's exactly what i'm doing right now but i'd rather reverse thing for a couple of reasons. Firstly i think it'll look better but mostly because i've bought a Demciflex dust filter and it's catching on the fans.
