Thanks for the reply, all I can say is you have confused me more than I was beforeNo idea but if I get 2 minutes to myself tonight I'll go measure one for you.
At a guess I'd say 12mm ID with a 1.5mm cross section, so that'll make it 15mm OD.
Hot damn I'm goodbeing 12.1x1.6mm.
How so? The o ring slips over 12mm OD tube and is a very snug fit, so it has to be operationally as close to 12mm ID as possible. The thickness (cross section) of the o ring is pretty chunky so that was an educated guess mentally comparing it to the o rings I recently bought for my custom DDC top.all I can say is you have confused me more than I was before
It took me 30 seconds to find this by Googling "O ring for EK-HDC Fitting 12mm". EK sell them as a kit (out of stock) but they list them as being 12.1x1.6mm.
Thanks order placedThere's plenty on fleabay. In fact, the supplier I got my DDC top o rings from have a bag of 100 nitrile 12.1mm x 1.6mm o rings for £6.
Shop is called sealsuppliesuk
Good good. I did see your original message and was about to say a link probably counts as a competitor, so I'm glad you found it.Thanks order placed
thanks again though I was struggling to find the correct size and even though I had already tried to use Google I was finding it hard to get the correct informationGood good. I did see your original message and was about to say a link probably counts as a competitor, so I'm glad you found it.
