Console gamer who wants to make the switch...
Looks good - the X makes sense if you have the funds and the lager sized GPU will pay dividends with regards to heat/noise and stability if you decide to clock it.
It's a tidy build with quality components for your money.
Go mini itx.
You know you want to.
ATX is so outdated and all those empty pcie slots that's never going to be used...sitting there feeling unloved.
Go mini itx.
LOL - i think if he was presented with another build he may genuinely start to think we're p***ing with him.
Although, his wife may actually believe something that small was only £500...
He might not be wrong ;)
Even harder now biostar has actually shown off a fully designed x570 board.. heatsink is a bit naff and active cooling.. indeed it's all in-house controllers but still...
Please stop! :D:D
Break down:
  • MINI ITX - basically smaller form factor - resulting in a considerably smaller case. Still an excellent B450 motherboard but no wi-fi built in (same brand and even better VRMs - as needs them in an iddy-biddy case). All other components are the same - but card choice will be limited to the mini. So same performance but all nestled in a smaller, compact case - but less room for expansion (but doubt this is an issue). Oh, and @tamzzy will be helping you with cable management as this is your first build... #justsaying :D
  • Full ATX - midi tower - larger case (compare sizes) - choice of card size (the larger being quieter) and the possibility of placing a larger cooler on the CPU in the future (again quieter running). And being full ATX more room for expansion and same for case - but again, probably not an issue.
  • X570 - nothing to do with your build - but very interesting to tamzzy and I and @orbitalwalsh's timing was perfect. :D
@Plec yes i saw your sly dig about cable management. naughty you. :P
like this:
Can take advantage of the price drops on 16GB 3200MHz & 3333MHz RAM:
My basket at Overclockers UK:
Total: £178.68 (includes shipping: £8.70)​
I'd pay the bit extra for the Predator there, tighter timings than the Fury which has lower frequency, may even overclock a bit.
Look, seriously now, this is messing with my head! Should I go for a Mini ITX? It's size may convince the wife that it's not costing a lot. If so, which would be the best MOBO?
Up to you - does the size of the unit matter?
Personally, i only build ITX builds if the room/space requires it - otherwise i give myself (others) room for expansion...
Have you actually looked at the size of a MINI ITX board and case? Don't confuse it with the MATX build earlier. There's a reason i joked about @tamzzy guiding you through cable management - the build may/will be trickier due to size constraints...
indeed, it was all in jest. :)
mini itx can be a wee bit trickier to build in (as a rule of thumb) as the case dimensions are generally smaller.
go with the ATX build listed. it's pretty solid.
