EE G.Fast connection, is it any good?
2 Aug 2004
Looking to get the fastest connection i can and with G.Fast available it seems my options are BT, Zen and EE. BT only guarrantees 150, zen says 202mbit minimum and EE says 183mbit minimum. EE is by far the cheaper that Zen but has anyone got it already, how does it perform???
Mark
28 Jan 2011
My Bt guarantee a minimum of 150 minimum, but since getting the service it has never dropped and my speeds on pc average around 270/300 dl and constant 50 ul.
29 Dec 2002
The sync speed on all of them will be the same, it's the same line, the same modem (except BT) and the same minimum speed for handback. Go with whoever is offering the best overall deal, remember to use Quidco/TCB.
OP
2 Aug 2004
As good as any other for the 'last mile' but it's the support and backbone you'll need to know about. What does http://dslchecker.bt.com show?
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
High Low High Low
VDSL Range A (Clean) 80 59.7 20 19 54.7 Available -- --
VDSL Range B (Impacted) 80 56.5 20 18.5 49.2 Available -- --
G.fast Range A (Clean) 330 316.1 50 29.3 271.7 Available -- --
G.fast Range B (Impacted) 295.4 222.3 40.7 20.2 202.2 Available -- --
Featured Products
Downstream Range(Mbps)
WBC FTTP Availability Date
FTTP on Demand 330 30 -- Available -- --
Caporegime
17 Jul 2010
Featured Products
Left in Jumper
High Low High Low
Featured Products
So you should get very good speeds, possibly even 300+ if everything works out and you pick that package.
Caporegime
18 Oct 2002
I think there’s at least one person here who does, and they were happy with it at the time. I can’t remember any more than that.
