what BT headphones do you use for running?
I may be shunned as it's what I use while lifting weights and cycling, not running, but I love my Jabra Elite Sport - https://amzn.to/2DHjvYS
They measure your heart rate while exercising, which is a bit of a bonus I think. This can be passed to Strava for example.
I've had a pair of MPow Cheetahs for 4 years now and love them - I own PowerBeats 2 too and the MPows are superior in every way in my opinion.
https://www.amazon.co.uk/Headphones...ronics&sprefix=Mpow+ch,electronics,127&sr=1-3
I'd worn them so much that the metal springed rod that runs through the neckband had actually corroded and snapped (due to sweat) and I managed to take them apart, re bend a hook in to the wire and put them back together again. Best £20 I've spent.
https://www.amazon.co.uk/Headphones-Mpow-Bluetooth-Sweatproof-Hands-free-Black/dp/B071RV7MH9/ref=sr_1_3?crid=1WH1C8SK1FT6I&keywords=mpow+cheetah&qid=1556725461&s=electronics&sprefix=Mpow+ch,electronics,127&sr=1-3
they look ok actualy
going by those, i found these, which could be better :
https://www.amazon.co.uk/Mpow-Headp...&pf_rd_p=653aa5af-b429-5ddd-a161-215094c7cde4
Those look similar build to my PowerBeat 2's, and it's the build that I don't like personally. Being specific, it's the loose / normal cable linking the two, because it's loose it sits on your neck weirldy and flaps around like I'd imagine a cold wet pony tail feels like!
oh i see, so the ones i linked to could be worse on that front, but i think being memory foam pads they should be a better fit, which brings me to.. possible to change my current pads to foam ones? (so they expand when you push them in your ear to get a better fit)
Haha just done.
No idea what’s best or what it means but I wear them around the house too and can leave my phone in the house and wander around the garden and not lose connection.
Looks like they’re more expensive than I paid as I must’ve got them in a Lightning deal but I wouldn’t hesistate to pay £30 for them.
