The Radeon VII Owners Thread
HeX
HeX
20 Jun 2004
Huddersfield, UK
Better pic of the 'gold edition' card:
26 Sep 2017
In the Masonic Temple
Wo
2000 core with 1147mv, 199% power limit, 1150 memory,
Used the 1318+ power table.
1200 memory gave green sparkles and flashes.
I'll try again later and up the voltage.
Woahh soldier,
Try this -
2000mhz with 1100mv , 1200mhz memory, 0% power slider (the mod increases the max tdp for you)
With the slider that high its causing the sparkles, with the reg mods i dont ever use the power slider anymore.
If the above fails try 1150/1180mv instead, also try putting the two core sliders together at 2000 i.e the min and max clock.
27 Aug 2005
Kent, England
Wo
Woahh soldier,
Try this -
Will give that a try. Got 2000/1150 with 1202mv game stable last night with 0% power slider so shall see how low I can get the mv now.
27 Aug 2005
Kent, England
1150mv, 2000 core, 1150 mem. Just played GTA V for 3 hours, no issues. Peak tJunction was 80, average was 52.
1100mv gave brightly coloured star flashes.
1200 mem was a no go even if I upped the voltage to 1200mv.
2100 core at 1200mv just BSOD.
My default voltage is 1104mv.
Overall I'm happy with that.
26 Sep 2017
Nice man, that's pretty darn decent as is
19 Feb 2007
ArcCorp
Testing a build I put together for a friend and in certain games after a few minutes I keep getting a black screen, Wolfenstein 2 after a few minutes at 1080P max settings the FPS are nice and high but it suddenly goes black, Driver crashes and then recovers itself, What could this be ? Temps are good, Junction temp is decent so I'm a bit confused.
6 Mar 2012
South West
I had the black screen when I was under volting my card when first testing just adding a few more mv solved the problem mine now runs 0.986mv 1900/1150 24/7
28 Nov 2018
London
That might be a problem with those certain games. I'm not able to run Wolfenstein 2 as well, black screen but with sound and many others around Google too, I just gave it trying to make it work. All the rest of the games of my library run just fine.
26 Sep 2017
I'm having a similar problem with world war z in vulkán, the sound carries on but the game turns into a grey screen
