Even if I won the lottery I would not buy this.
Nor me, it's total overkill. I'd spend about £4k on parts and build a PC myself.
I suppose if money is no object and you can't be bothered to build a machine, it might appeal.
I'm guessing footballers and other insane wage people who like a bit of PC gaming. I'm guessing there's some out there as I know some footballers in particular game quite a bit, albeit on console.
I'm assuming some people buy these as otherwise what's the point of spending time/resource to build them?
Yes though the Intel CPU gives both the high clock speed and cores.. for now.It's a beautiful system, just goes to show what you can achieve when you want the best of the best.
No Ryzen option though? Putting in a threadripper 32 core would have been awesome.
Is it the best though?.. Because the last thing I would be wanting to be doing is faffing around getting things to work.... Thats the problem with pc's the more complicated you make them, the less compatible they are with software/games and with a 32k pc you expect you would be able to throw anything at the pc and it would work with no probs... So Im guessing if this system was ever sold there would be loads of completes due to software/games compatibility.
The people who would buy this, would be loaded and knew quite little about pc's, but wants the best.
The way it's been built I'd assume it just works straight out of the box, overclocked, without the user needing to tweak anything.
But can it play Cry...
YES IT CAN PLAY CRYSIS!
Like who tho
Just think of the bugs you'd have to sort out to run games properly... You would constantly be having probs with it... I did enough of "hair pulling out" when I had a sli setup,, never again.
I like a pc just to work without complications, You would be spend more of you time getting games to run on it, then actually gaming....... So count me out too, Im going grey fast enough, without speeding up the process.
i watched the video, i dont see the point in it.
i watched the video
Honestly why would someone want 2 systems in one? With the amount of power, with Windows having multiple desktops, multitasking with one system shouldn't be an issue, I really don't get it.
