Please recommend an intuitive and 'lite' FTP Server
14 Aug 2018
Many moons ago I used to use BulletProof FTP server but it seems that it is no longer freeware (Which I think it was).
What free solution do you guys recommend that are both resource light, intuitive and fairly quick to setup.
Ah.... back in the day I used Serv-U and BulletProof, pretty sure both were shareware rather than freeware, but from memory had trials.
https://www.serv-u.com/
Just looked at the price now.... OUCH!
FileZilla seems the free option, BulletProof is also on a subscription based model. Personally Ubuntu’s inbuilt server does me quite nicely.
Have used Filezilla in the past, both server and client.
Thanks will give that a look over.
:D Cheers, I'm going to pop Linux on a few other machines but my main one will be Win10.
+1 for FileZilla, been using it for years for various purposes at work.
Cheers folks, I've installed FileZilla and got it configured in a few minutes. Works fine and dandy. ;)
Just wondering if there is any way to increase the size of the font in the log window? On my 1080p monitor it's fine but a little small on my preferred 1600p one.
