Hi all,
Hoping you can help me put together a new build for a friend, primarily used for editing 4k video (After Effects and Cinema 4D), with a budget between £3-4k (obviously the cheaper, the better).
Currently his wish list includes something like the following (though these parts are not set in stone should better options be available or if this would be overkill for what he is doing), as well as the rest of the components to get this up and running;
Intel i9 9900k,
64GB DDR4-2666Mhz RAM,
NVIDIA GeForce RTX 2080,
512GB Samsung 860 Pro SSD (for OS),
512GB Samsung 970 Pro NVMe M.2 SSD,
1TB Samsung 860 EVO SSD
Any help would be awesome, as I'm at a bit of a loss as to what kind of machine he would need to do this kind of work.
Thanks in advance.
Intel i9 9900k,
Thanks in advance.
