This is what RTX looks like on GTX cards. a slideshow
And what does it do on the Vega 56?
These Nvidia demos are completely different to the crytek demo and aren't in anyway comparable ion the slightest.
We are talking about Ray Tracing outside of RTX, don't be so bloody touchy, its pathetic.
And there are no comparison possible. Crytek demo has not been benchmarked on GTX cards and AMD haven't made DXR drivers so you can't look at Metro Exodus, Tomb Raider, BFV or the nvidia demos.
The only compariosns that can be done is Vega 56 vs RTX cards in Crytec demo where RTX cards are 8x faster, or the Turing vs Pascal cards in the games with DXR .
You are the one that is paranoid and making up numbers out of thin air to try and defend AMD.
Because we are talking about Ray Tracing on cards OTHER THAN RTX cards, you lot are just anxious that we are saying RTX cards are not necessary, its why you two are in here crying "oh but RTX cards are still better" go way with that paranoia...
So now 30 fps is playable to you? I have read so many comments on how 30 fps isn't acceptable but when it comes to anything other than NVidia, it is fine?There is a definite benefit to having dedicated hardware for Ray Tracing but you only need that for nVidia's implementation because like everything they do its so badly optimised, that doesn't take away from the RTX cards tho.
You could make the same scenes in Cryengine to the same quality and it would run above 30 FPS on my 1070. That's how bad nVidia's implementation of Ray Tracing is.
In the long run a hardware solution in theory takes away the need for the developer to special case stuff, frequently test and tweak their implementation to ensure quality and performance, etc. the Cryengine solution looks great but it will have situations where it doesn't quite work right, slows down significantly or has other artefacts, etc. unless the developer uses special casing and so on.
Unless someone makes a massive breakthrough - which definitely hasn't happened yet - CPUs simply don't have the performance to do software ray tracing even via tricking it up using things like voxel representations to compete even with first generation RTX hardware when the tech matures.
The performance depends on which GI settings are used. Usually on Xbox One it takes 4-5 ms of GPU time and on a good PC (GTX 780) it takes 2-3 ms (AO + Sun bounce, no point lights, low-spec mode). The fastest configuration is "AO only" mode; this provides large scale AO at a cost of about 2.5 ms on Xbox One
Wow, I try to be nice and get that.Also Greg, don't be a #### doxing me, use my forum name when addressing me![]()
Again with the "but but... RTX cards superdooper....." no one is disputing their Ray Tracing prowess
You misunderstand Ray Tracing in this instance, its GPU and API agnostic, it doesn't need special RTX hardware or software. That's the point of it.
If by ray tracing you mostly mean cube maps with a little bit of raytracing on top then yeah sure, but people saying "oh look raytracing on a cheap card makes RTX overpriced cards stupid" are somewhat missing the point.
- First we prepare voxel representation of the scene geometry (at run-time, on CPU, asynchronously and incrementally).
- Every frame on GPU we trace thousands of rays through the voxels (and shadow maps) in order to gather occlusion and indirect lighting.
No, no cube maps, environment probes, just pure Ray Tracing.
Furthermore, whenever possible we still use all the established techniques like environment probes or SSAO. These two factors help to minimize how much true mesh ray tracing we need and means we can achieve good performance on mainstream GPUs.
In Cryengine a lot of it is using voxels (essentially representing the scene at a cruder resolution using the CPU) and some shader processing power:
It is a hybrid CPU/GPU solution but basically the same as other CPU attempts it runs into the realistic limits of the CPU or general GPU compute to do lots and lots of rays. This is largely used for indirect shadows and some global illuminations and is not a full unified ray tracing solution for the whole lighting model and has many limitations such as only really works properly with large static geometry and becomes increasingly less accurate with smaller and moving geometry and needs a lot of care to avoid artefacts like light leaking.
The demos that incorporate it also fake up other elements of ray tracing using cube maps, etc. hence why it isn't really comparable to a matured RTX solution even though that is also hybrid and uses a fair few render buffers, etc.
From the article;
Environment probes are used to build cube maps, so again crytek say they are using cube maps and layering a small amount of voxel based ray tracing on top, not running on pure ray tracing.
Did you even read what they wrote?
It is obvious they aren't running on pure ray tracing if you think about it - full resolution reflections would require a minimum of 2 million rays per frame (realistically more) at 1080p and they are talking about a few thousand (which is fairly realistic for a CPU or hybrid CPU/GPU compute implementation) so they have to be carefully special casing and using a lot of environment probes, etc. to do it in the demos - you aren't limited to purely screen space with alternative methods you can render the scene from other positions into a buffer and prioritise for realtime the ones closest to what the player will notice - which is a common technique - other surfaces/objects might have reflections that update at a much slower rate.
